camshaft sprocket clock
Need a clock in the garage, anyway...so found a use for a worn cam sprockets
Would be cooler to have a properly-plated 5/16" x 1-1/2" washer, not the zinc Home Depot one.
You know what would be really cool? Doing a dual 12/24 hour clock using a full front end gear set: cam sprockets, crank sprocket, and for completeness: oil pump sprocket, and all the water pump and tensioner rollers, etc.
Then you could put a 12 hour clock face on the crank sprocket and 24 hour clock faces on the cam sprockets. You'd probably need a pretty beefy clock mechanism to turn the whole affair.
Would that be cool, or what?
Why not just hook a starter up to the engine on a stand and feed it the right number of amps at 12V...attach clock gearing and hands to the accessory pulleys to mount on the crank...noisy clock that would be.
