AC/C question? Blower resistor
Did some searching and couldn't figure if I have MBS or not. As soon as I turn on the AC, the blower operates on high at all settings. Is this the resistor or something else?
Electron Wrangler
It is either the resistors thermal bypass engaged all the time or the DEF relay stuck on.
If you pull the DEF relay you will know which.
It is certainly most likely the resistor pack thermal bypass.
On the resistor pack (unplug car loom) if you have ~0 ohms between pins 8 & Pin 6 the thermal bypass switch is stuck on. (= MBS symptom without the 'magic' on/off part)
Alan
Alan
