eprom's for sharktuning
I've been speaking with John Speake about using my new Sharktuner MK1 to tune my 1986.5 twin-screw. John suggested a pair of2732A-200ns EPROMs for the data. However, they are not available anywhere.
Can anyone suggest an alternative that would work just as well?
Thanks in advance,
Thanks in advance,
Former Vendor
Eric,
I just received 10 of them from WWW.JAMECO.COM
They had them in stock and shipped to CT from CA in 5 days UPS COD
Ed
Ed
Inventor
If you have a EPROM burner with an external power supply, there are many 2732 or 2732A variations available. The EZ and LH will work with 100-400ns.
Pocket Programmer III
Used 2732 usually work just fine. Many available on eBay.
Example eBay search:
(2732*,27C32*,AM2732*,D2732*,ETC2732*,ET2732*,HN2732*) (eprom*,chip*,nmos,dip)
You'll need a UV eraser box too. Depending on the eraser, it can take 1/2 hour to erase older 2732 EPROMs, so it's good to have a handful of 2732.
Eric,
Ed
Ed
So, 250ns version would be ok? Not too slow?
Former Vendor
Inventor
250ns is fast for the EZ and LH processors. I've used 400ns w/o issue.
The ST-Micros which Ed has linked would work fine, depending on your burner.
Old AMDs are particulary robust, I've found. (Although they are slower to program, and slow to erase.)
http://www.ebay.com/itm/2732-Eproms-...-/220822609650
Administrator - "Tyson"
I bought my last batch from John Speake.
