Air pump for intercooling???? Yes it works, but how well????
1 Post
Check this out ... 10 psi of boost through a beautiful intercooler that requires no plumming or water and is super easy to install. Yes it is true, and here is a shot from the Sharktuner
Just call me Wile E. Coyote - Super Genius![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
1 Post
It is still there, nothing changed with that, you just cant see it behind the intercooler.
I am flying to NYC thursday morning to do a stage 2 install for a guy there. We will be documenting everything. He is going to take pictures, notes, and track everything including times, while I do the complete install. He wants to go do a dyno run after, but I dought we will get a before run in.
I had the same idea you did. However, I have read that using the A/C system for an intercooler only lasts for cooling bursts of limited time before the cooler is heat-saturated.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Captain Obvious
Super User
Super User
Are you using crankcase ventilation to cool the intercooler? But that doesn't make sense. I can see smem funky tubing on the vavle cover.
