928 Forum 1978-1995
Sponsored by: 928 Specialists
castrol 10w60, synthetic
Old 04-06-2012, 07:22 AM
Vilhuer
Vilhuer's Avatar
928 engine design was done in early seventies. Back then these modern oils didn't even exist. Their excellent features are wasted in old engines. For example Porsche museum puts Valvoline 20W50 into cars they restore even though factory normally uses different brand oils based on sponsor deal they have done for production line use. Mobil, Shell whoever is current new car favorite provider don't seem to have right products for factory to use in 30 year old models.
Old 04-06-2012, 01:29 PM
gruffalo
gruffalo's Avatar
Originally Posted by Vilhuer:9420965
Many locals use it without problems. Those of us who are slow drivers on track or don't go there at all use cheaper Valvoline 20W50 simply because we don't need 60 at top end. Very few use any Mobil variant in engine as most feel they do not work. At least avoid any and all 0Wnn oils available regardless of who makes it.
Why? Why is a 10w40 better than a 0w40, for example?
Old 04-06-2012, 08:03 PM
dprantl
dprantl's Avatar
Because in order to make a 10W-40 oil for example, you start with a 10W oil and add viscosity modifiers so that the film strength hot is 40. As the oil is used and the modifiers wear away, hot film strength gets closer and closer to a 10W.
Dan
'91 928GT S/C 475hp/460lb.ft
Old 04-07-2012, 02:34 AM
Vilhuer
Vilhuer's Avatar
And in case of Mobil 0W it seem to cause premature wear in for example eighties BMW engine cam lobes. Not good at all for our old design engines.
Old 04-07-2012, 05:08 AM
FUSE69
FUSE69's Avatar
Have any of you guy's tried Valvoline's VR1 10w-60 synthetic?
I've been using Valvoline's 20w-50 with good results, but it is a dino oil, so am wondering if it's worth switching to their synthetic...
Old 04-07-2012, 06:21 AM
Vilhuer
Vilhuer's Avatar
Friend uses it in his '90 GT as cheaper alternative for Castrol. He loaned it for me for Helsinki-Stockholm-Nurburgring trip last summer. 3k+ miles at motorways and autobahns and several laps at the 15 miles long old ring and only problem was too high for our liking consumption at the track. That can be expected even with Mann-Hummel setup. Oil was fine at short bursts up to 160mph and longer periods in 120-140mph at autobahn.
Old 04-07-2012, 07:33 AM
993turbo
993turbo's Avatar
I used Castrol 10w 60 ''M'' oil in my 928's earlier. No issues. I have now switched to ''Gulf Competition Racing Oil'' 10w 60 Synthetic Ester based. Very happy. :-)
Old 04-07-2012, 01:48 PM
FUSE69
FUSE69's Avatar
How much do you estimate you used per lap and what was the oil pressure like once idling back to the carpark after a lap?
I have 20w50 here for the next oil change, so maybe for the change after that I will give the 10w60 a try...
Old 04-07-2012, 03:15 PM
gruffalo
gruffalo's Avatar
I'm gonna give the Gulf 10w60 a try. This thread is inconclusive anyway. A 10w60 is:
-too thick
-too thin, since it's based on a 10
-too new, multigrade didn't exist back in the day...
Old 04-07-2012, 04:10 PM
Vilhuer
Vilhuer's Avatar
Maybe 5 laps and 1L was normal so its little over 1L/100km. It changed somewhat depenging on how much traffic there was at the track meaning was high rpm used all the time or not. Oil pressure remained same as always. At idle it is 2.5 bar IIRR and don't need much revs to go above 3 bar. Weather wasn't super hot though.
Quick Reply: castrol 10w60, synthetic
