WYAIT for Regulator Housing (79)
I reinstalled my fuel system today, cranked it up, and was running great. Then, out of nowhere, my regulator housing O-ring started barfing coolant. Disappointment, despair, then...parts order assembly.
What else should I be looking at doing with that thing off to replace the O-ring and left and right gaskets? So far I have:
O-Ring
Left + Right Gaskets
Paper gasket for oil filler assembly
and....?
O-Ring
and....?
Are you referring to the water-bridge that connects the two cylinder heads and holds the thermostat?
If so, replacing the t-stat + o-ring and t-stat seal that fits into the water bridge would be a good idea. Also replace any swelled or leaking hoses there.
