Rear Quarter Window Removal Procedure
I had trouble getting my rear quarter windows out, until I used this method. I haven't seen it documented any where just yet.
First, window out!
![](http://members.rennlist.org/lt_texan/RQW1.jpg)
From the inside, using a couple butter knifes, and starting at the bottom middle, lift the inside rubber lip and push it out over the window metal frame.
![](http://members.rennlist.org/lt_texan/RQW2.jpg)
It's a bit hard to get started but one you work around an inch or so, the window starts to give outwards and it is easy to roll the rubber lip to the outside with your thumb. Raise rubber up with knife, push out with thumb.
![](http://members.rennlist.org/lt_texan/RQW3.jpg)
It became so easy that I lifted and push the rubber out for almost all of the bottom of the frame save 4 - 6 inches on both ends.
![](http://members.rennlist.org/lt_texan/RQW4.jpg)
At this point it is easy to just push the bottom of the window out and pull it down and away from the outside of the car.
Hey, worked for me!
First, window out!
Hey, worked for me!
