928 Forum 1978-1995
Sponsored by: 928 Specialists
Help ID this
Old Mar 17, 2012 | 06:10 PM
Kalspeed's Avatar
Kalspeed
Default Help ID this
Chasing a vacuum leak today due to a low idle (and recurring vacuum wheezing sounds) and came across this on the passenger side near the coolant reservoir. Seems to be missing a hose.
Anyone know what it is and what is connects to?
Sprayed brake cleaner in the general area and the idle rose briefly.
Old Mar 17, 2012 | 06:15 PM
Speedtoys's Avatar
Speedtoys
Air pump valve?
930 113 147 01??
Old Mar 17, 2012 | 06:21 PM
Kalspeed's Avatar
Kalspeed
Is there another hose which should be connected to it?
Old Mar 17, 2012 | 06:22 PM
SeanR's Avatar
SeanR
One rubber hose going in to it from the air pump, one on the opposite side going to your intake, one metal one going to the exhaust (might be a rubber bit between valve and metal hose, and then the vacuum line on the top.
Old Mar 17, 2012 | 06:28 PM
Kalspeed's Avatar
Kalspeed
OK so that little nipple protruding under that vacuum hose is not a fitting?
So I should suspect the vacuum leak is under the air box in that maze of vacuum hose?
