Now that i have my early style motor out and getting ready to build up its late model replacement, iv noticed that i will need to use the late style PS pump and that will require changing out the pressure line to the rack. can i just use the late style line (banjo with washers at the pump) vs the compression fitting old style? feed line from rez should be ok....
It uses the old alt/powersteering bracket... just bolted right up..
I'll see if I can find some pics of the setup..or I'll get some this weekend when I'm at the shop..
