928 Forum 1978-1995
Sponsored by: 928 Specialists
Recalls
Old Mar 13, 2012 | 07:01 AM
FreedP's Avatar
FreedP
Default Recalls
Found this last night.
http://www.dealerrater.com/recalls/Porsche/928/
Old Mar 13, 2012 | 03:25 PM
danglerb's Avatar
danglerb
Any idea if any of these are still supported by dealers or Porsche?
1991 Porsche 928 Recall
Item Affected: POWER TRAIN:AUTOMATIC TRANSMISSION
Date Announced: 8/24/1992
Description of Recall:
A PLASTIC FILLER PIECE LOCATED IN THE AUTOMATIC TRANSMISSION WAS INSTALLED WITHOUT SUFFICIENT SUPPORT. THIS FILLER PIECE CAN MOVE BECAUSE OF THE HYDRAULIC PRESSURE IN THE SYSTEM, AND NOT ALLOW THE AUTOMATIC TRANSMISSION TO KICK DOWN TO A LOWER GEAR.
Action Needed To Fix It:
DEALERS WILL INSTALL A NEW FILLER PIECE WHICH HAS A SECURING BRACE TO PREVENT MOVEMENT.
Find your local Porsche Dealer.
1990 Porsche 928 Recall
Item Affected: FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Date Announced: 6/19/1990
PLASTIC FUEL GAUGE MOUNTING NUT MAY CRACK AND ALLOW FUEL TO LEAK FROM THE FUEL TANK.
REPLACE MOUNTING NUTS WITH NUTS OF AN IMPROVED MATERIAL.
1987 Porsche 928 Recall
Item Affected: FUEL SYSTEM, GASOLINEELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Date Announced: 3/17/1987
RETURN FUEL LINE HOSE MAY NOT BE OZONE RESISTANT.
INSTALL A NEW HOSE WHICH IS OZONE RESISTANT.
Item Affected: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL:CATALYTIC CONVERTOR
Date Announced: 7/23/1989
INADEQUATE HEAT SHIELD ABOVE CATALYTIC CONVERTER COULD OVERHEAT.
REPLACE HEAT SHIELD FOR CATALYTIC CONVERTER WITH A LARGER, IMPROVED HEAT SHIELD.
1986 Porsche 928 Recall
1985 Porsche 928 Recall
Item Affected: ENGINE AND ENGINE COOLING:ENGINE
Date Announced: 8/9/1985
THE ENGINE CARRIER HAS A FAULTY WELD TO THE SUPPORT BRACKET EYES. CONSEQUENCE OF DEFECT: THE WELD COULD GIVE WAY AND THE BRACKET EYE SEPARATE FROM THE CARRIER. WITH HIGHER MILEAGE ACCUMULATION A BREAK IN THE ENGINE CARRIER COULD DEVELOP AND RESULT IN A STEERING BLOCKAGE, LOSS OF CONTROL WITH POSSIBLY AN ACCIDENT.
REPLACE THE ENGINE CARRIER AND THE CARRIER SUPPORT.
1982 Porsche 928 Recall
Item Affected: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS
Date Announced: 5/17/1982
DUE TO THE IMPROPER INSTALLATION OF HYDRAULIC BRAKE HOSES, THE HOSE COULD RUB AGAINST THE RIM IN CERTAIN WHEEL POSITIONS. BRAKE FLUID LOSS COULD RESULT, CAUSING A DEGRADATION IN THE PERFORMANCE OF THE FRONT BRAKE SYSTEM. THIS WOULD CAUSE AN INCREASE IN VEHICLE STOPPING DISTANCES.
DEALER WILL REROUTE THE FRONT BRAKE HOSE AT NO COST TO OWNER.
1981 Porsche 928 Recall
Item Affected: SUSPENSION:FRONT:SHOCK ABSORBER
Date Announced: 4/8/1981
FRONT SHOCK ABSORBERS ON SOME VEHICLES MAY HAVE IMPROPERLY WELDED MOUNTING EYES. THE SHOCK ABSORBER MOUNTING COULD SEPARATE AND CAUSE THE SUSPENSION TO COLLAPSE IF VEHICLE IS DRIVEN ON ROUGH ROADS FOR A LONG PERIOD OF TIME.
THE FRONT SHOCK ABSORBERS ON ALL INVOLVED VEHICLES WILL BE CHECKED AND, IF NECESSARY, REPLACED WITHOUT CHARGE.
1980 Porsche 928 Recall
Item Affected: STEERING:WHEEL AND HANDLE BAR
ON THE INVOLVED VEHICLES, THE UNIVERSAL JOINT WHICH CONNECTS THE STEERING SHAFT TO THE STEERING RACK MAY HAVE BEEN IMPROPERLY POSITIONED DURING ASSEMBLY. IF VEHICLE IS DRIVEN ON POOR ROADS FOR AN EXTENDED PERIOD OF TIME, THE CONNECTION BETWEEN THE STEERING SHAFT AND UNIVERSAL JOINT COULD LOOSEN AND CAUSE EXCESSIVE STEERING WHEEL FREE PLAY.
DEALER WILL INSPECT AND REPOSITION THE UNIVERSAL JOINT CONNECTION AT NO COST TO OWNER.
1979 Porsche 928 Recall
Item Affected: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTSISC:CALIPER
Date Announced: 10/12/1979
THE TWO MOUNTING BOLTS FOR EACH OF THE LEFT AND RIGHT SIDE FRONT CALIPERS HAVE BEEN IMPROPERLY TORQUED DURING ASSEMBLY. THE TORQUE WRENCH USED IN THE ASSEMBLY MAY HAVE BEEN MECHANICALLY DEFECTIVE.
DEALER WILL RETORQUE THE FRONT BRAKE CALIPER MOUNTING BOLTS TO PROPER SPECIFICATIONS.
Item Affected: SERVICE BRAKES, HYDRAULIC:FLUID
THE BRAKE SYSTEM RESERVOIR ON THE INVOLVED VEHICES MAY CONTAIN CONTAMINATED BRAKE FLUID. THIS FLUID COULD EVENTUALLY SPREAD THROUGH THE COMPLETE BRAKE SYSTEM AND DAMAGE BRAKE COMPONENTS.
THE DEALER WILL INSPECT AND CORRECT ALL BRAKE COMPONENTS AT NO COST TO OWNER.
1978 Porsche 928 Recall
Item Affected: VEHICLE SPEED CONTROL
THE ELECTRICAL CONTACT POINTS INSIDE THE STEERING COLUMN SPEED CONTROL SWITCH MAY HAVE BEEN IMPROPERLY MANUFACTURED. AS A RESULT, "STICKING" COULD OCCUR AND CAUSE THE SPEED CONTROL SYSTEM TO STOP FUNCTIONING.
THE DEALER WILL REPLACE THE SPEED CONTROL SWITCH, IF NECESSARY, FREE OF CHARGE.
Item Affected: STRUCTURE:BODY
THE ROOF MOLDINGS ON EACH SIDE OF THE VEHICLE ARE NOT SECURELY FASTENED.
THE DEALER WILL SECURE BOTH LEFT AND RIGHT ROOF MOLDINGS WITH ADDITIONAL SCREWS ON ALL INVOLVED VEHICLES, FREE OF CHARGE.
Item Affected: STEERING:LINKAGES:KNUCKLE:SPINDLE:ARM
BOTH THE LEFT AND RIGHT STEERING ARM ARE ATTACHED TO THE FRONT AXLE KNUCKLE WITH TWO FASTENING BOLTS. THESE BOLTS ARE BEVELED BELOW THE HEX HEAD TO FIT INTO THE CHAMFERED HOLES IN THE STEERING ARM FOR PROPER FASTENING. THE CHAMFERING IN THESE STEERING ARM HOLES WAS OMITTED DURING MANUFACTURE. SHOULD THE BOLTS LOOSEN, THE STEERING ARM COULD BECOME LOOSE.
THE DEALER WILL CORRECT THE DEFECT BY CHAMFERING THE HOLES.
THE FRONT AXLE CASTER AND CAMBER ADJUSTERS COULD CRACK DUE TO IMPROPER MANUFACTURE. SHOULD THIS HAPPEN, THE ADJUSTERS COULD LOOSEN AND CAUSE WHEEL MISALIGNMENT. ALSO, THE TIRE ON EITHER THE LEFT OR RIGHT SIDE COULD EXPERIENCE EXTENSIVE WEAR.
THE DEALER WILL REPLACE THE CASTER AND CAMBER ADJUSTERS WITHOUT CHARGE TO OWNER.
Item Affected: PARKING BRAKE:CONVENTIONAL:MECHANICAL:LINKAGE AND CABLE
THE EMERGENCY BRAKE CABLE MAY HAVE BEEN IMPROPERLY ROUTED DURING ASSEMBLY. CONSEQUENTLY, THE CABLE COULD CHAFE AGAINST THE BRAKE LINE OR BRAKE HOSE BRACKETS. CHAFING COULD LEAD TO DAMAGE TO THE EMERGENY BRAKE CABLE.
THE DEALER WILL REROUTE THE EMERGENCY BRAKE CABLE WITHOUT CHARGE TO OWNER. .
THE EXISTING BRAKE HOSES MAY HAVE BEEN TWISTED DURING ASSEMBLY. CONSEQUENTLY, THE HOSE COULD CHAFE AGAINST THE EMERGENCY BRAKE CABLE. PROLONGED CHAFING COULD RESULT IN LOSS OF BRAKE FLUID, THUS AFFECTING REAR BRAKES.
THE DEALER WILL REROUTE THE REAR BRAKE HOSE, IF NECESSARY, WITHOUT CHARGE TO OWNER.
Item Affected: EQUIPMENT:OTHER:LABELS
THE SYMBOL IDENTIFYING THE LIGHT SWITCH ON THE INVOLVED VEHICLES DOES NOT MEET THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 101, "CONTROL AND DISPLAYS".
OWNER WILL BE SENT THE CORRECT SYMBOL FOR SELF INSTALLATION OR INSTALLATION BY THE DEALER.
CERTIFICATION LABELS INSTALLED IN THE INVOLVED VEHICLES MAY NOT INCLUDE THE DATE OF VEHICLE MANUFACTURE, AS REQUIRED BY FEDERAL REGULATIONS.
DEALER WILL INSTALL THE CORRECT CERTIFICATION LABEL WITHOUT CHARGE TO OWNER.
Old Mar 13, 2012 | 03:28 PM
whatudrivin's Avatar
whatudrivin
Unless someone else has Porsche contacts I could try calling my local dealer and seeing what they have to say.
Old Mar 13, 2012 | 09:07 PM
linderpat's Avatar
linderpat
Old Mar 14, 2012 | 01:27 AM
danglerb's Avatar
danglerb
Made me hungry for some kettle corn.
Old Mar 15, 2012 | 08:31 PM
h011yw00d's Avatar
h011yw00d
Bump. Anybody check on this?
Old Mar 15, 2012 | 08:54 PM
SMTCapeCod's Avatar
SMTCapeCod
I have letter from this one in the documentation from P/O
"1986 Porsche 928 Recall
Old Mar 16, 2012 | 12:06 PM
davek9's Avatar
davek9
Anyone know what this part is they are talking about ? Is it the Cross member that the Eng sits on?
"1985 Porsche 928 Recall
REPLACE THE ENGINE CARRIER AND THE CARRIER SUPPORT."
Thanks,
DaveK
