Cam cover breather elbow availability WTB
I'm after the elbow that bolts to the cam covers and connects to the crankcase breather system.
The part I am after is 928 107 733 02 (right side of car, front, elbow goes up).
Porsche says this part is NLA (as is 928 107 733 00) and only 928 107 733 01 is now available. This one has the notch on the wrong side. See this thread for further info:
https://rennlist.com/forums/showthre...ferrerid=68202
My issue is Porsche wants $100 for the "01", while the old "02" were listed at $18. Does anyone have a source for the "02" part or even a used 00, 01, or 02?
BTW, this is for my 944S2 (same cam cover).
I'd expect 928 International (www.928intl.com) to have one. This part was apparently used on all 5L 32V engines. I've got one on the engine in the garage on the stand but they probably have one already removed and they're closer to you...
Eric, I have one of the .00 variants marked "0R" (actually, it's the same one I photographed and showed in the first three pictures—excluding the initial exploded parts diagram—in post #1 of the thread you referenced).
If all else fails, I could make that available to you. However, as that one has the internal restrictor/throttle, I'd suggest you get whatever non-throttled one is cheapest and just add another keyway if you need to (like I did; see post #31 in that thread).
dc Automotive shows 928.107.733.02 available (used, I think) for 14.08 USD.
Electron Wrangler
You can grind a slot in the other side of a rear one (its not rocket science), how about calling 928 Intl?
Mine are at 45 degrees back & down (completely reconfigured breathers).
Alan
Alan
Thanks all for your help. dcAuto postage is about $70, so buying locally is easier and not much more expensive. I have emailed 928Intl for cost and postage estimate.
Unfortunately postage is a killer to Australia.
