dads 928 makes me wonder???
Dads race 928 idles low and the rpms move with the sound of exhaust, it will go up a little then down then up and so on and just low idles like that, now I know that's a racecar but can I make my auto s4 do that? If so is it the idle thing under the airbox I have to play with? Thanks guys
Most of us spend time trying to get them idling properly. You could just install a stuffed O2 sensor if you don't want it to idle properly. Don't play with the thingy (MAF) under the airbox.
http://en.wikipedia.org/wiki/Jetronic
Wikipedia has a good general introduction and comparison of the systems.
Moving idle usually means the fuel air ratio isn't tracking right, typically air is getting in via some path other than the air meter, as in vacuum leak.
The good way to get a lumpy idle is with a radical cam, high lift, overlap (intake opens before the exhaust fully closes so some weird flow can happen).
OTOH you won't pass smog if the idle drops out of a narrow rpm band in the test.
Electron Wrangler
Yes quite unnecessary... the rest of us are busy trying to avoid an uneven idle.
Always good to ask yourself:
...Why would this really be a good thing? - before making any changes from stock behaviour
Alan
Alan
Just because it sounds 'cool' doesn't mean that the car is running properly. Wish some people around where I live would figure this out.
And the sound you are describing is called 1 of 2 things usually.
1. Loping - hotter cams and such
2. Idle Surge - idle goes up and down on its own. Caused by numerous things amiss with your motor.
If the idle moves in a pattern, surging up and down, bleh, something is wrong.
If the idle moves in a random, almost dies but doesn't lope, sweet, something is right.
But too much lope, or can't smooth it out even raising the idle speed as much as possible, can be a PITA because from time to time the motor will die and it won't pass smog.
You might be able to sharktune with a set of chips that allow switching between several sets, and make one with a low lopey idle.
BTW I am almost never going to say don't do it, just pass along what you should be prepared for if you do do it.
Unwanted idle variations in fuel injected cars are typically caused by air leaks. These manifest themselves as wavering idle, uncontrolled high idle, and inability to get idle speed down.
