928 Forum 1978-1995
Sponsored by: 928 Specialists
seatbelt warning light
Old Feb 23, 2012 | 11:09 PM
hb253's Avatar
hb253
Default seatbelt warning light
I replaced my battery last week (the old one was 12-13 years old and only holding 60% charge).
I finally had a chance to drive the car tonight and confirmed that the previous problem with dim dash lights was resolved. I can now see the gauges. However, I still notice a slight flcutuation in brightness depending on engine speed.
One fault that was not resolved was the seatbelt warning light coming on intermittently. I've read other threads that say it might be due to a bad alternator. Is it possible this is a symptom of a bad seatbelt relay instead?
I've cleaned some grounds already, but they were mostly clean anyway. All interior lights work correctly.
Hugo
1984 928S
1979 911SC Targa
Old Feb 23, 2012 | 11:25 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
if your lights are fluctuating ...... you have a bad alternator.....
Old Feb 24, 2012 | 05:02 PM
hb253's Avatar
hb253
Is it that clear cut, or would removing it and having it tested be of any value?
If I do end up having to replace it, I'll need to decide between a Delco or avoid mods and go with an original style.
Hugo
1984 928S
1979 911SC Targa
Old Feb 24, 2012 | 05:28 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
first id clean ALL the grounds. i replaced the engine ground,seemed to help. i also did the delco mod. works well, but i can tell she gets a little heat soaked.
