928 Forum 1978-1995
Sponsored by: 928 Specialists
fuel pump
Old Feb 22, 2012 | 01:16 PM
shelby151's Avatar
shelby151
Default fuel pump
I have a 82 928 just wondering if i should hear the pump prime when i turn the key on,reason is i have starting issues and if i put a little fuel in the intake she starts right up,also if i shut her off she starts back up only does it when it sits for a long while.
Old Feb 22, 2012 | 02:40 PM
brutus's Avatar
brutus
The pump runs when you engage the starter. Your check valve by the pump might not be holdong pressure. Or an injector leaks over time. Some late model V W s now run the pump when you open the drivers door just in case you are going to push the button to start the car.
Also your cold start injector or thermal time switch may not be doing their job. Which is to squirt fuel into the intake when the engine is cold.
Old Feb 22, 2012 | 03:23 PM
shelby151's Avatar
shelby151
Makes sense because when i turn the key and it does not start i hear the pump as i stop turning over the the motor.
Old Feb 24, 2012 | 09:39 PM
Luis_M's Avatar
Luis_M
On my 81 928S, the fuel pump runs very briefly when I turn the key to the On/Accesory position, before I turn it to engage the starter
