928 Forum 1978-1995
Sponsored by: 928 Specialists
Exhaust Manifold
Old Feb 11, 2012 | 01:02 AM
Paperman90's Avatar
Paperman90
Default Exhaust Manifold
Hey can you guys tell if the Exhaust Manifold from 87 S4 928 fit on my 84 S2 ?
thank for the help
Old Feb 11, 2012 | 01:18 AM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Nope, '87 manifolds have a three bolt pattern, your '84 has a 2-bolt. The '85-86 32V S3 exhaust manifolds are 2 bolt and will work on your '84, but IIRC there are other issues with respect to the passenger side S3 manifold lining up with the 16V downpipe. A real expert will be along shortly to weigh in, consider this a placeholder...
Old Feb 11, 2012 | 08:24 PM
Paperman90's Avatar
Paperman90
I would like to think you for the help
Old Feb 13, 2012 | 02:56 AM
Podguy's Avatar
Podguy
Cut off the flanges and weld on new ones.
Old Feb 13, 2012 | 03:01 AM
danglerb's Avatar
danglerb
My local muffler guys, two pretty sharp old timers, didn't want to mess with welding on the old stainless exhausts. I forget what they didn't like, but I was looking to have the 5/8 bank exit flange moved up the pipe an inch or so, fairly simple, and they didn't want to do it.
US 85/86 manifolds are two bolts per port and fit on early cars with some adjustment to the downpipe to correct the 2.25 inch offset between model years.
Old Feb 13, 2012 | 10:50 AM
Melo928's Avatar
Melo928
All discussed here - even pictures of modified manifolds:
https://rennlist.com/forums/928-foru...lds-to-s2.html
