CAM COVER PROBLEMS
CAM COVER PROBLEMS
Hey Guys. Take a look at these pics. I need to know what you think about
fixing these 2 broken cam cover studs. On the bright side everything looks
really good inside the cam tower.
928 Collector
1. Be VERY careful, I'd tape it all up immediately after degreasing enough surface to stick painter's tape or something similar, to prevent metal cuttings from entering your head.
2. No big deal, just drill (or if you're not confident HAVE it drilled) the centre with a small bit, try a reverse drill bit, and if that fails, you will need to properly drill and tap.
