Speed sensor wire location and color?
Hello all,
I am about to install a new radio with GPS and need to know where i can find the speed sensor wire on a 1994 GTS Automatic.
Thanks,
Martin
Thanks,
Martin
Electron Wrangler
Central Electric Panel (fuse/relay panel) - in passenger foorwell.
Plug P position 15
See attached plug P is the 3rd yellow one from the left - labelled on the frame base and on the plug.
See the the Empty "R" connector - for an example of the pin position numbers - same on all plugs
15 is lefts side and 5th one up (top)
Alan
Plug P position 15
Alan
Plug P position 15
Alan
Plug P position 15
Alan
One last question; any advise on how I should tap into the cable.
Hello Martin, Alan,
I am also installing a radio with GPS (Becker Indy pro) and have similar questions; I know which cables to tap in to for speed and reverse lights, but the big Q for me is where to do that? At the panel? seems scary to me. Is there a possibility to put an extra wire into the plug? tap in to the wire in a different location?
Thanks in advance.
Kind regards from Madrid
Thanks in advance.
