New headlight relay - interesting
I hadn't realised that there were wiring differences as well with the dim dip system other tnan additional wires to connect to dim dip controller socket. (Peculiar to approx mid 87 to late 88 MY GB cars only)
My 88SE had it - return to conventional functionality like ROW cars merely involves pulling the Dimdip controller box out of it's socket and changing the coding plug from IIRC pins 1-3 connected to pins 1-2 connected. If you just pull the coding plug as well the headlights rise when the light switch is turned to position 1 (parking lights or side lights) but don't illuinate until the light switch is turned to position 2.
I like the dim-dip functionality - however my 89 has the coding plug changed, so that position 1 the driving lights come on, *and* the headlights come on low-voltage dim but remain down. IIRC for 89 UK cars, the dim-dip module is hiding behind the dead pedal (87/88 its stuffed behind the ECU's).
I just replaced my headlight relay as well with a new one from the porsche dealer. I have a euro 1984 s2 and the dealer showed me that the part number had indeed changed twice during history. It is now a plastic cover. Old one was aluminium. And no wiring diagram print on the outside.
But it does work exactly the same as my old one: when turning from dipped beam to city lights, the headlights stay up but with no light. When switching to fully off position, the headlights retract as they should.
Leo 1984 s2 euro 5 spd. Netherlands.
I thought normal operation was for the lights to stay up but not lit when you remove the ignition key with the lights switched full on. - So you can clean the headlight bucket without flattening the battery.
Electron Wrangler
I just pulled the defrost relay on my 86.5 to avoid current drain...have one from an 88 on hand...same exact part number stamped on them...just different production date stamps-- and different pins/wiring on schematic.
Electron Wrangler
I believe the rear defoster relay was he same all years, they may have changed the diagram - but is it electrically the same...?
Alan
Alan
Basic Sponsor
Sean,
Checking with your VIN it is a USA/Canada car and no dim/dim option.
Is it possible the car went to the UK with Military personel and was modifed.
Send the relay back for a full credit and we will double check its operation here.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
