Bilstein - SHOCK HORROR
I loved the concept, hated the manufacturer. The MK3 spring rate is rather high..and the TEMS valve rates on rebound are far too low..theyre a compression only adjustment on that.
Not to mention being stuck with Tokico on spec RX7 racing, and they were a one-weekend lifetime cartridge cost to manage.
Just my two cents.
Just my two cents.
Basic Sponsor
An electric switch in the cabin
Great news! They may be available by the time I have some $$ in the Porsche fund.
Basic Sponsor
Most of the Bilstein strut/shock kits we sell on 997's are adaptive and rear shocks are only $270 each so not that bad.
I expect these'll be their B16 "damptronic" system, which is based on their PSS10 coilovers iirc but instead of a manual adjuster **** (and about 8 or so possible settings), you get 2 - a softer one and a more sporting one (call them what you will), adjusted electronically via a switch in the cabin. In any case, these are excellent dampers - and my experience is that Bilstein are normally very good at judging their settings (i.e. for a road car it's no great loss to not have all the different adjustability "steps")
The only downside is you need to run a wire in from each unit to a central control unit. It's not wireless (yet..)
Just my two cents.
Just my two cents.
I use Koni yellows now though.
Rubbed a lot, and after -1- weekend (about 2hrs of work) you could feel where the overheated shocks were on the car. Filling the shock tube with ATF when you dropped in the cartridge helped a little...
Yeah these were different - mine was an '87 and it was a fully replacement strut instead of an insert - I wondered how inserts could work as well since you were losing diameter by forcing it to be smaller than the existing strut. I just did some Solo II though, not nearly the same punishment as you were getting in Spec Rx7.
ECS on my 3000GT VR4 back in the day. Sure did go from Jeckyll to Hyde with a flip of the switch. The active aero, on the other hand...
Adjustable suspension has come a long way with the reactive/charged fluids.
