I wonder if there's any room to mount a dual-remote bypass filter setup?
I've always wanted to install a setup like this.
http://www.ebay.com/itm/NEW-AMSOIL-D...#ht_1195wt_956
Maybe in the rear somewhere?
It would be sweet to have the filters in a place where I can just reach down and remove/install. I've got a drain-plug valve installed now, so I just slide under a pan, open the valve, and it pours out. Easy. I want the filter change to be just as easy, without having to jack the car. Plus the bypass will filter the **** out of the oil.
i used to have a volvo turbo and put one of those setups on it. the filter was a MAJOR pita and the turbo was very close. I thought that it was getting the filter spper hot..
it was great. best mod i ever dd to any car..........
It was a pain to install, but was very effective?
Administrator - "Tyson"
I wasn't aware 928 engines were failing due to dirty oil from an inadequate oil filtration system.
Prolong claims you can drain all the oil out of a Dodge Viper in Arizona once it is treated with their stuff. Maybe the key is having Bobby Unser driving? Sort of like Kibort's success with his engines?
I said nothing about 928 engines failing from dirty oil.
installing the kit was not bad at all.
what was the pain was removing the oil filter in it's origional location. the turbo bloced most of the access.
it made all future filter changes a breeze.
Even though the convenience of filter removal would be nice, I wouldn't want to install more hoses with hot pressurised oil in the engine bay than absolutely necessary. To get it out of the way of a turbo I can understand, but can't see the advantage with filtration, over what is already proven to be adequate.
Oil's cheap ... I'd rather just change the oil regularly than look to extend the interval by using bypass filtering.
1 Post
So if I understand this correctly, one would be installing a bypass filter instead of a full flow filter to filter only some of the oil just for the convenience of filter changes?
Or would one leave the full flow filter in place and add the bypass filter? Three filters to change?
I just see this as added complexity, even more flex hoses to resolve what issue?
Just trying to understand why, as bypass filters went out of favor in the 50's if I recall, possibly for good reason.
Dave
Dave
If I did install one it would be a temporary addition to the full flow filter. I'll start on my X5. With shut off valves, no racing or tract time, just hwy cruise time with it connected. Also Baldwin bypass filters have the correct pressure valves in them already.
