Pain in the pod
Of course not. There is a nut which sits in hex recess on LHS, which longer of bracket bolts screws into to. But no matter how carefully you align things, the thing gets pushed out of recess and drops off! There's no room to get finger in and hold in place either.
I had to disconnect cluster and pull pod forward to replace the nut. I have now glued the sucker in the recess! That should hold it but won't be able to work on it again till weekend.
On plus side I am getting faster at dealing with cluster edge connectors with all the practice!
How do other lister cope with that nut? I don't know if it's on the pre digidash pods.
I lined up the holes with a small Phillips screwdriver through the washers and spacers and then gently threaded the cheesehead screws in place. It also helps to tape the spacers and washers in place on the left-hand side of the cluster. That said, if gluing the nut works, I'll try that next time I’m in there.
Yes I had taped the bushes and washer on the LHS when I first put pod back in, and thought I was home free with the very long bolt on LHS through the bushes and located in threaded hole at top of pod. But then I ran into the nut problem and obviously wasn't as gentle as you - the nut would pop out even just using a screwdriver to line things up nicely. I don't think glueing that nut could cause any problems in future work with the pod so I'll see how it goes from here.
