question. rear driver upper control arm mount at the x-member squeaks. is it the bolt holding the bushing that normally squeaks or is it the alum park of the bushing on the member?
just curious - how did you determine control arm squeaks? did you rig up a stethoscope type hose while driving? or does it do it when you man handle it? I would've suspected the sway bar first.. hmm
id hear this very short bouncy/squeak while driving. got home and if i push lightly on the driver rear coroner i can hear it. had my bud push down while i used a stethoscope at all the joints, and bingo! found it. i was thinking sway bar too, but i know i added some graphite to the new bushings when i installed them.
