Pretty much nothing else fits AFAIK. The lock is supposed to fail so that you can get the cap off, so your condition is unusual. I think turning the key CCW should unlock it. The gauge is not at all linear, and you can go quite a way at E before getting the low fuel light in my experience.
Give it a bit more torque CCW, it should undo , mostly with locked caps you have to drill a hole in the red outer so you can peg the inner and outer together and unscrew the inner from the filler neck. Do a search, you should find some pics of a dismantled cap.
jp 83 Euro S AT 54k
Thats the second reported failure recently where the "fail to unlocked" mechanism seems not to have worked.
The usual failure mechanism is that the rear part of the U shaped pawl breaks off - this is under constant stress from the spring when the cap is locked. Seems a stress crack forms & breaks. The material (nylon?) is not a good choice. When it breaks this should allow the spring to keep the pawl teeth always engaged - this is the unlocked posistion with ratcheting clockwise and inner & outer parts fixed together counter-clockwise.
The locked posistion is when the outer cap spins freeley in either direction wrt the inner cap.
Its possible in this case that the teeth on the locking pawl have been rounded over enough that they won't look in either direction - of that you have wear on the inner lock part ribs. However seems very odd it ratchets one way but won't lock the other way..
Seems you will need a new Pawl at least and possibly the inner cap part to fully fix it. . You may also have to sacrifice the outer red cap shell with a small hole to get it off. If you can live with non-locking - I think you could just glue the inner & outer together after this.
I had a similar issue when I first got the car. I felt like I was missing something or being stupid. In the end I gave up and forced the cap off. I then found the O-ring was missing inside the cap. Once I replaced it the cap and lock worked as they should.
I have to wiggle the key in my cap to get it to "catch" and work. The first time took about 30 minutes. At least, if anyone steals my car, they won't get further than one tank of gas.
