So my old hag (1980 US 5-speed) is about ready for the move. I hope she makes it. I'm leaving Sunday morning to Las Vegas then leaving there Monday morning and catching he 40 in Kingman.
Here is what we've done.
steering rack swap
wheel bearings
ball joint swap
brakes
engine seals & gaskets
engine installation
fuel injector hoses
transmission syncros
torque tube bearings
pilot bearing
clutch
release bearing rebuild
cv joint boots
alarm system removal
fuse/relay panel swap
door locks
ignition key
ignition switch
pod removal(s)
instrument cluster swap
instrument cluster lights
speedometer gear
fuel gauge
alternator
belts
coolant
coolant bottle
windshield washer pump
radio wiring
speaker wiring
door panels rebuild
courtesy lights
rear hatch swap
cruise control
rear view mirror
windshield
wheel well shields
tires
a/c system: ( a project in itself )
vacuum lines & pots
a/c switch rebuild
mixer flap control cable
new expansion valve
new drier
new thermostat
hoses rebuild
wiring repair
flush
evacuate & fill
