928 Forum 1978-1995
Sponsored by: 928 Specialists
Speedo Pulse Question - Fixed
Old Dec 8, 2011 | 07:40 PM
Boatman's Avatar
Boatman
Smile Speedo Pulse Question - Fixed
Do any of the electrical guys know what voltage the speedo pulse for an '81 should be? I'm getting around 6 volts. Should it be 12 volts? I'm trying to track down the problem with my speedometer. Thanks.
Old Dec 8, 2011 | 09:35 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if you can provide more info on what your doing ,
what is or isnt happening
and what you have done
and what was the last thing you fixed,
it will make a diagnosis easier
Old Dec 9, 2011 | 01:05 AM
WICruiser's Avatar
WICruiser
I am pretty sure it is suppose to be 12 volts but in my case it was only 8 volts. Speedo is currently out to be checked out so I will interested in what you find.
Old Dec 9, 2011 | 01:10 AM
Boatman's Avatar
Boatman
I've followed posts describing the sensor circuit. Testing in the spare tire compartment I verified that the switch on the diff was working making and breaking a circuit as the wheels turned. On the central electrical panel I checked voltage at H1 - 12v. At H2 I got a pulse of 6v when the wheels turned. Pulling the dash I followed the circuit paths from the rivets behind the speedo and had 12v at 10r on the right plug (power in) and ground at 7r on the right plug which connects to 11r. Reconnecting the plugs to the cluster I measured a pluse of 6v at the center rivet behind the speedo as I turned the wheels. Everything seems to check out except the pulse is only 6v and I didn't know if 6 is okay or if it should be 12v. If it is supposed to be 12 I'm not sure were I'm getting the loss. Thanks for your help.
Old Dec 9, 2011 | 06:15 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
As you found, it is a simple circuit - switched 12 volts. While there are other possibilities, poor connection in the spare tire well and at the instrument pod connectors and foil seem to be the most common problems.
Old Dec 9, 2011 | 05:55 PM
Boatman's Avatar
Boatman
Thanks Wally. I'll keep searching for the bad connection.
Old Dec 13, 2011 | 07:34 PM
Boatman's Avatar
Boatman
I followed the great write-up in Dwayne's Garage (thanks Dwayne) and fixed my problem. I cleaned all the contacts and found that I had continuity issues behind the speedo. I soldered all the rivets to the traces, put in all back together and now can tell how fast I'm going. Another problem soved. I'm getting there.
