steering wheel vibration between 65-85+...?
88 S4, Red...intake R&R (plus a lot of other things) done by Tampa928...: )
Ok, so I changed the rims to 19" and put brand new Nitto tires all around on the car. At the same time I lowered it as well. Up to 65mph I dont get any vibration, after 65 or so it starts vibrating a fair amount. I have had the front tires balanced twice by 2 different shops. Each time they said it was off but fixed it. Each time it vibrated less but still vibrates more than it should or usual.
Note: I have not had the alignment done after replacing tires, rims and lowering it,... (yes I know I SHOULD HAVE, I just did not think about it)...
I am seeing where on the front inner tires, could the vibration be caused by the lack of alignment...?
At this point I have to do the alignment, I have just been waiting to order new shocks first and do the alignment at the same time.
Just curious if this could be the cause of the vibration...
thank you,
thank you,
I had fronts replaced (Kumho's) due to lateral runout which was about 60+. You could visibly see the lateral run out on the balancing machine. Worth a check at the tire place perhaps. YMMV
