928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel cooler insulation
Old Nov 13, 2011 | 11:11 PM
Whitesands's Avatar
Whitesands
Default Fuel cooler insulation
The insulation around the fuel cooler on my car is crumbling away.
Has anyone replaced it and did you use?
Thanks.
Old Nov 13, 2011 | 11:12 PM
SeanR's Avatar
SeanR
Bicycle handle bar foam. Fits great and it's cheap.
Old Nov 14, 2011 | 06:31 AM
Maybach_Man's Avatar
Maybach_Man
semi ridgid plumbing pipe lagging
Old Nov 14, 2011 | 07:32 AM
Hilton's Avatar
Hilton
9x25 (25mm ID, 9mm wall thickness) closed-cell neoprene pipe insulation can be slipped over the cooler. I also used 9x20 to insulate the third ac line after rebuilding it on the car (I have a hydraulic crimp tool).
There's also a size that fits the fuel rails for insulating them - but I'm too lazy to go downstairs and read the size on it
It can also be "welded" using superglue, so if you do have to cut it (fuel rails), you can seal it up again and not worry about it coming off. It comes in 1m and 2m long tubes at various local hardware stores. Its closed-cell so won't hold water, and also oil resistant.
edit: also just remembered that I use this stuff to replace the crumbled foam seals around the edges of the plates in the front fenders (e.g around the ABS unit) - one of the thinner walled ones just tucks into the groove perfectly.
File Type: jpg
File Type: jpg
Old Nov 14, 2011 | 09:44 AM
jeff spahn's Avatar
jeff spahn
I did the plumbing pipe insulation. Works well
Old Nov 14, 2011 | 09:45 AM
jeff spahn's Avatar
jeff spahn
Isn't working on your car nice with the engine out!
Old Nov 14, 2011 | 12:05 PM
Whitesands's Avatar
Whitesands
Thanks guys, plenty of ideas there.
Looks like a trip to Home Depot via the bike shop.
Old Nov 14, 2011 | 02:07 PM
T_MaX's Avatar
T_MaX
Wrap your closed-cell neoprene pipe insulation with some aluminum foil tape will help lock in the cool and block out more heat.
Old Nov 14, 2011 | 06:35 PM
ALKada's Avatar
ALKada
Is it fire retardent or would that be a little too late for it to be fire retardent....?
