Ignition switched to off, key removed, engine still running....
Electron Wrangler
Alan
It should be added, don't disconnect batt on a running engine, hence the above procedure. I forget the reason, voltage spike? but it is one of the more important "don'ts" on this car.
Seems this can happen with the HAZ switch as well.
Unless P/O swapped the switches between haz/defrost plugs.
Old thread but interesting. Made me remember my problem on my 993. Due to screwy Bowden cable which runs between ignition and tiptronic shift lever you could not
turn car off. P mechanic said pull fuel pump relay if it ever happens. WD-40 fixed it.
I don't have that black 86.5 anymore..but this seems to be a common and scary problem. If it happens after you've pushed in the defrost button, try pulling it out. Good chance the engine will stop.
I've seen the Defrost switch do this too, however I would not stuff a rag into the Engine air intake, if you do, you will destroy the MAF screen(s) when the rag gets sucked in.
I would pull the fuel pump fuse and let her run out of gasoline.
Dave
Dave
Team Owner
FWIW simply placing your hand in front of the MAF will kill the engine, no rag is needed.
If a rag is used it could damage the MAF screen
