87 928s4 on stands
I've had my car up on stands for two day and when I went to open the drivers door I noticed that it was pinched and difficult to open. should there be that much flex in in the frame? Will this correct itself when I get the weight back on the tire?
![Name: 928 pics 025.jpg
Size: 66.5 KB](https://rennlist.com/forums/attachments/928-forum/579071d1320103561-87-928s4-on-stands-928-pics-025.jpg)
You'll be fine once you put the weight back on the tires. Also note : DO NOT REMOVE THE SHOCK TOWER CROSSBAR UNLESS YOU HAVE WEIGHT ON THE WHEELS. You risk a busted windshield otherwise.
