Is it possible
Is it possible
i recently changed the motor oil from 5w30 to 20w50, not only the motor is quiet, no tapping noise and oil pressure is at 4 after the car is warmed up at idle. but an amazing thing is i used to have drips and drips of oil under the front of car and now i have a coin size of one or two little mark on floor, is it possible?
Barry
Barry
For some strange Minnesotan reason, I'll run 5w40 in the winter. If it's 0C or above then go with the 20w50. The manual shows what Porsche thinks about weights and temperature ranges.
Your oil change place probably doesn't stock the thick oil these cars like in the first place.
You shoud be fine
Where you are, and underground, I wouldn't worry about it unless you're planning a February trip to Terrace, and even then......
While we're on the topic (again)
There are of course, many different opinions out there, but after reading and learning way more than I ever needed or wanted to know about engine oils, I've had no issues with this choice.
Yes....
Yes you can...and I would recommend Castol for any number of applications....and used it for years in my bikes and GM products,....but....
Wait a minute. Where you live, I'm guessing the starter is already having issues in the morning.......
Once again, spellcheck would be nice......
hi barry
yes it is very possible!!! when my car had the correct oil in it there was no leakage at all. At the moment i have light flushing oil in it (its on stands with no front suspension at the moment) and its dripping
