Headlight Relay Setup..
Archive Gatekeeper
Alan, thanks 1x10^6 for the detailed outline, this is very timely as I am going to be digging into an H4 upgrade on Hebert's car soon, and will document the process, dummies-style.... May even do it on my own car!
Ive taken photos of the critical points of power/ground access, and how the HW all kinda goes together.
I dont have a GOOD photo of the final solution yet..but will tonight if I get home soon enough.
You will spend what feels like an eternity crimp/soldering blade ends onto wires tho.
..and the photo I do post, wont be the final-final image...because this was a quick job to see the results. I'll be going back and removing crimped junctions with soldered and sealed ones later.
Here it is:
Electron Wrangler
Here is a diagram.
Alan
Ah..you found the thread..
On the pass side, the alternator block us right beside the ABS pump, great source for +.
I used the radiator upper mount bolt for ground on that side..it was the closest, easiest, major bolt to ground near the light too.
On the pass side, jump post and again, radiator mount bolt for ground.
I have not yet done the full wiring where the high also triggers the low, but that should be like a small sun lighting up once I do that too.
I will also be upgrading to Bosch 0 332 019 109 relays. They have diode protection from voltage spikes, and have the dual 87 configuration you'll need.
It..just wont be until the weekend of Nov 6th, before I have time to do this..unless I find some work days to do it.
Electron Wrangler
The best grounds are the ground point in front of the radiator in front of the jump post and the ground on the apron next to the ignition final stages.
Fuse with a big fuse right at the positive tap point if your other fuses are going to be in the headlight buckets.
Alan
Alan
Question for Alan..
It works fine however when the fog lights are turned on the high low beam stays on and doesn't not switch back to low beam unless the fog lights are turned of.
Any ideas?
Electron Wrangler
Herman - How is it wired? - The version I showed should not do that...
Alan
Alan
I did the install whereby the hig beam and low beam are on at the same time when high beam is selected.
Any ideas?
Any ideas?
Alan
I'll draw up a little schematic and get you some details of the relais I used a little later today.
Apart from the electrical I did find some interesting issues (mechanical) related to the headlight position alignment I made some pictures of the steps/mods I used to correct this and will post them at the same time or open an new trhread.
Alan this is the way I wired it
When the fog lights are not activated low and high beam change without any problem.
