928 Forum 1978-1995
Sponsored by: 928 Specialists
bubbles bubbles
Old Oct 12, 2011 | 10:18 PM
smyth1's Avatar
smyth1
Default bubbles bubbles
cant seem to get the air out of the power steering on my 87.fluid level is staying the same and i do not see any leaks.with the cap off the res i'm getting constant bubbling after cycling back and forth a few times doesnt seem to get any better.any ideas?thanks
Old Oct 12, 2011 | 10:44 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
what was the last thing you fixed?
Old Oct 12, 2011 | 11:09 PM
PorKen's Avatar
PorKen
Inventor
I have this problem too on my '86.5. The PS fluid foams up the first time I turn the wheel when the engine is cold, but is fine after it's warmed up.
I changed the fluid, and tightened the clamps on the reservoir, to no avail.
Old Oct 12, 2011 | 11:54 PM
JG928S4's Avatar
JG928S4
Had an Audi w/that problem. Had a pinhole leak when temperatures up, sucked air.
Old Oct 13, 2011 | 01:26 AM
laufenOutLoud's Avatar
laufenOutLoud
+1, old hoses can suck in a little bit of air. Start with the oldest hose...
Old Oct 13, 2011 | 01:33 AM
White Lightnin''s Avatar
White Lightnin'
Veteran: Army
I read the title and thought it was a thread about AO...
Old Oct 13, 2011 | 10:20 AM
Deantec's Avatar
Deantec
I had this happen over the weekend turned out to be the small hose off the bottom of the P.S. tank was cracked on both of the S bends when you straightened it out looked like Swiss cheese, Temp fix with small hose spliced to end of old hose.
