AT removal/repair ideas....It's out.
#121
Dan
I removed the 9 or so bolts that hold the pump housing, then I installed the 2 bolts and pulled the assembly off the trans. Now that it is on the bench I need to seperate the pump from the piston to replace the Oring. I see a little damage to the gasket where it had a bubble in it.
Thomas
Thomas
