Dipstick tube O-Ring
Cleaning up around the front of oil pan and wondered if there's any special trick/caution required to change this o-ring. Is it as simple as removing the dipstick tube retaining bolt at the belt cover and then pulling the tube up out of the pan to replace the ring?
yep. Just do what you asked. I did mine during engine refresh. Put a rag over the hole while you have the dipstick out or something you need will fall in there sure as sh*t.
