Below are two parts I need to replace. They both attach to the seat memory unit under the driver's seat. The first is a piece of spring steel that attaches the memory control unit to the seat frame. There's one at each end of the control unit, and they flex a lilttle to let the control unit move.
The second piece is an electrical plug that connects the heater switch to the memory control unit. It appears to be similar in design to the infamous 14 pin connector next to the positive battery connector in the engine compartment. It's missing the cap, which lets the contacts fall out.
Anybody happen to know the part numbers for these parts? I can't seem to find them in the PET anywhere. Even better would be if someone has one or both that they would be willing to sell.
If it makes any difference, they are from a '93 GTS.
1)Since 1990 the DS memory seat became standard issue (no longer a part of the available option) So you should be able to find it on cars being parted out.
2)Put a blop of JB Weld on it if you can't find a cap
