928 Forum 1978-1995
Sponsored by: 928 Specialists
94 GTS window trim
Old Sep 25, 2011 | 08:13 PM
77tony's Avatar
77tony
Veteran: Army
Default 94 GTS window trim
Is there a tip(s) on how to install a new piece of exterior rubber trim strip that sits in the metal window trim ? TIA. 77Tony
File Type: jpg
File Type: jpg
Old Sep 25, 2011 | 08:48 PM
jpNcos's Avatar
jpNcos
No advice but I need to do this also. Do you have the part number? Did Roger have these?
Old Sep 25, 2011 | 10:33 PM
77tony's Avatar
77tony
Veteran: Army
JP, Roger has not sent me the invoice as of yet so I don't know the P/N. I think Roger has them in stock because I received this trim pretty fast after I ordered. 77Tony
Old Sep 27, 2011 | 02:35 AM
kelanel's Avatar
kelanel
928 537 321 03 -left driver
928 537 322 03 -right passenger
have mine and tried once for passenger side, just got bloody fingers from the scraping of the glass against my cuticles. any kind of tool maybe to slip it in w/o taking the door apart, or an adhesive?
Old Sep 27, 2011 | 10:13 AM
Fabio421's Avatar
Fabio421
Man of many SIGs
You need to take the trim off the car, install the seal into the trim ( soapy water may make it easier to work with ) and then install the seal and trim as one piece. A hammer and a rubber mallet work well. Put the rubber mallet on the trim and strike it with the hammer. Work your way from one side to the other. It takes alot more force to install it than you would think but the trim is surprisingly tough.
Old Sep 27, 2011 | 11:03 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if you remove the trim from the door you will probably damage it or the painted surfaces,
And then you wont have a secure way to hold the trim while you install the rubber seal
What I do is remove the door panel,
then inner rubber seal at the top of the door on the inside,
this will let the window fall clear of the edge seal,
then remove the 2 felt rub brackets,
then carefully pry the old seal out,
put some silicone grease on the first few inches of the new edge seal , start at the rear and work forwards,
the seal has a unique 3 way gripping area thats very hard to install it can be done,
Also try to have the work area in the sun to keep the seal warm
Old Sep 27, 2011 | 01:02 PM
77tony's Avatar
77tony
Veteran: Army
Did use Stan's method. Seemed to be the best route to take without sacrificing the new paint. Tricky, but got it done. Thanks to all. (U2 Stan!) 77Tony
