Tensioner Oil?
I use a visene bottle with the tip drilled out ,
this makes it less likely to blow the inner clamp ring off the boot due to overpressuring the tensioner.
If you do this job yourself don't forget you'll need to set the cam timing too. I used Porken's 32Vr tool - much easier than trying to use a dial gauge. I'd go as far as saying it is a must (along with a belt tensioner tool)
(I used to live in Dubai and one day spoke to a young guy and his partner at a fuel station en route to Oman - in a slate grey non-sunroof S4. I wonder if that was you and / or your car)
I will be doing the job myself due to I have lost faith in any of the garages out here, just waiting for some parts.
