928 Forum 1978-1995
Sponsored by: 928 Specialists
Rear end noise
Old 09-13-2011, 06:58 PM
thundershark
thundershark's Avatar
Default Rear end noise
Originally Posted by vanster
If your tires are 6 years old regardless of the amount of tread, they should be replaced. 6 years is just about the end of the life of a tire sitting on the ground.
Returned from the tire shop this morning, they rechecked the c/v assys., the rear end lube, and checked the rear tires on their Force Variation machine that will tell if the tire has flat spots or out of round conditions and rebalanced them. No real defects found. One tire needed to be relocated on the wheel 180 degrees. After the check ride, no difference. I will use my friends rear tires soon for a test. If no change then I must assume the axle bearings are at fault. Doesn't seem to be any real tests for this condition. I will report back after the tire/wheel swap. It seems this vehicle is subject to a lot of road noise as per discussions about using heavy noise insulation which I have none of in the back under the carpet. Could it be "normal" road noise coming from there? Marty
Old 09-15-2011, 04:18 AM
Podguy
Podguy's Avatar
Gee the tires on my 20 yo Toyota Truck are ten years old and are as smooth as the day I bought them.
Old 09-20-2011, 02:30 AM
thundershark
Same problem after borrowing and testing a friends wheel and tires for the rear. Next I will check the wheel bearings. Thanks to all that replied with helpfull ideas. Marty
Quick Reply: Rear end noise
