How to remove pillars?
Hi,
I had a leak from sunroof and driver side pillar is slightly warped. I want to remove it and see if I can get it fixed or replaced with another one. Anyone has a guide on how to remove pillars?
Thank You!
Thank You!
928 Collector
Drop the roof liner at the front by removing scresw and undoing (CAREFULLY!!) the plastic press-clips and removing visors. Then start at the top and pull the pillar cover toward the rearview mirror along the windshield
They are only secured by two clips on their inside that fit over the metal seam of the pillar, but are partially trapped at the bottom by the dash (which you can't move) and at the top by the headliner (which you can move once you remove the clips and screws - hence heinrich's advice).
Administrator - "Tyson"
![](http://eaglemountainrentals.com/images/makita%20dpc6410l%20concrete%20saw.jpg)
