Cam timing effects, 32V
#62
Inventor
Due to unexpected demand, I will take the alpha 'BumpSticks' to the plater's tomorrow. They should be ready the week after. (<-FB)
Roger should have some by mid-Dec!
#64
Looks good Ken. I ground down an old wrench but I may get one of your wrenches in the future.
I bought your cam timing tool but ended up being Lazy and eye balled it.
I must have got it close.
I will check it this winter since I will have lots of time to play.
Brad
Brad
#66
Inventor
Brad - the wrench is a bonus. The real improvement here is the socket, which locks the big washer to the hub behind the gear.
Greg - thanks!
Greg - thanks!
#67
Inventor
Ooooo...aaaaah...
![](http://members.rennlist.org/porken/PKBumpStick.jpg)
#69
Inventor
Glenn - the 'alphas' are going fast - (EDIT: all sold)
Roger will have them in Dec. The only noticeable difference will be a brushed finish on the socket.
FYI: the 'sprocket' design provides a way of holding the socket firmly when installing or removing. It can also be used to (lightly) pry it off if it is tight. The two holes align with #1 and #6.
