Selling parts I have collected over the years
#31
Adding:
2 wiring harnesses from jump post to engine $25 each
1 gas filter(purolater) $5
1 front license mount
3 belt tensioner bodies $5 each
1 alternator cover $15
1 OEM alternator hose $25
1 tow eye
1 oil pump gear
1 tow eye
1 oil pump gear
#32
Man of many SIGs
Adding:
1 GTS Insulated air tube - New in shipping tube. 150 obo
1 used 85-6 Idle Air Stabilizer $50 obo
#34
Adding
2 ac compressor engine block mounts $15 each
#35
Michael, I tried to PM but you are not accepting PM's. Paypal kaberez@mindspring.com. I am dropping off the injectors tomorrow for a fellow Canadien. Maybe I can drop yours off too?
#38
3 Covers:
Driverside perfect. $50
Passengerside: 1 vertical inch crack on he reverse lense you can see from the back but almost is invisible from the front. Plastic housing behind brake like is broken through the clear and part of diamond cut is missing. $20
Passengerside: 2 inch crack in the housing that extends into the reverse lense. Plastic behind brake light has nickle sized blemish from wrong wattage bulb. $25
Hope this helps.
Hope this helps.
#39
Adding
OEM GTS antenna and cable $100
#40
Adding:
New Clutch Hose - Flexible(Chassis to Engine) 87-95 928.423.077.07 $75
Used S4+ Rear under engine cover: $50 Oops
#42
Adding:
3 horizonal grill slats in good shape - has red paint overspray - but attachment points are good. $50
1 set of Porsche wheel locks with socket key $50
1 Pre S4 mirror switch and harness connector - wires are cut
1 S4+ mirror switch and partial harness -
#44
Adding:
GTS manual shifter
GTS manual shifter
