928 Forum 1978-1995
Sponsored by: 928 Specialists
Parallel-flow condenser for late 5-speed?
Old 08-30-2011, 09:59 PM
dprantl
dprantl's Avatar
Don't you have a phone with a camera or something...
Dan
'91 928GT S/C 475hp/460lb.ft
Old 08-30-2011, 10:09 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,074 Likes on 1,183 Posts
Originally Posted by Tampa 928s
If your compressor grenades then you WILL have to replace the condenser,
I didn't.
Old 08-31-2011, 01:04 AM
jpitman2
jpitman2's Avatar
Hilton, FWIW, I think I have seen Bruce Buchanan in Sydney post some notes on landsharkoz about parallels he has fitted....unless my memory fails me again. I know he has posted about replacing auto tranny coolers with externals to avoid problems with the internal cooler in the rad...
jp 83 Euro S 53k
Old 08-31-2011, 02:22 AM
Hilton
Hilton's Avatar
jp 83 Euro S 53k
Yep I popped in and spoke to Bruce, but his view point is that on the late manual S4's, the condenser is large enough that it has enough capacity for r134a, and that its not worth him doing the conversion and fabbing brackets etc. over the stock one. The parallel one Bruce uses on earlier cars and autos doesn't much cooling capability beyond the condensers I've already got.
I'm just in the throes of planning a full AC refresh on my 89 and exploring alternatives - a neighbour has recently bought an i30 so I figure I'll drop by and measure it to make sure before I pick one up to play with
Old 08-31-2011, 04:16 AM
jpitman2
jpitman2's Avatar
Hilton, I refurbed my ac compressor last year, new hoses, converted to R134, no other changes, seems to work fine, keeps inside cool in 40C ambient, so not sure what the issue with early condensors is. Pretty sure its a serpentine. If my condensor craps out, would obviously pay to look at putting in a parallel, but there isnt any point right now.
jp 83 Euro S AT 53k
Old 08-31-2011, 09:21 AM
Hilton
Hilton's Avatar
jp 83 Euro S AT 53k
The issue with the early ones, at least from my understanding, is their size relative to the anaemic airflow from the pusher fan at idle speeds in non-moving traffic.
I have one of my 928's in pieces at present, and the condenser looks like its seen better days. I don't know whether it leaks - but suspect it may, so am exploring parallel options. If I can find one I'm happy going with then I'll do it, as everything else in the system will be new and I'll have the chance to ensure there's no mineral oil anywhere near it.
Old 08-31-2011, 10:38 AM
dprantl
dprantl's Avatar
I agree that the later 928's have a large/efficient enough condenser to sufficiently cool their relatively small interior volume with either R12 or R134a. However, if one needs to replace their condenser and there is a drop in parallel-flow solution for under $200, that is something I would definitely go for instead of spending more on a new more expensive one of an older less efficient design, or risk a leak or blockage with a used one.
Dan
Old 08-31-2011, 10:48 AM
Tampa 928s
Tampa 928s's Avatar
This is where I purchased mine: http://www.familycar.com/
$178.57 plus shipping, I had to enlarge the mounting holes for the receiver dryer other then that dropped right in.
Old 08-31-2011, 12:09 PM
dprantl
dprantl's Avatar
I can't find one on there for that price. For an '80, it only lists the $350+ Behr:
http://www.familycar.com/store/?N=16...294962569+9171
For a '91 GT, it lists the Behr and the ACI is $207.14:
http://www.familycar.com/store/?N=16...294963735+9171
Dan
Old 08-31-2011, 07:43 PM
Hilton
Hilton's Avatar
Any chance you can measure the dimensions of the parallel one? Height/width/thickness
Old 09-01-2011, 10:08 AM
Tampa 928s
Tampa 928s's Avatar
I went to the site and the universal is not listed but there are several other sites that offer it for a few more dollars.
Core 22 inches
Height 14 inches
Thickness 3/4 inch
It seems they have stopped offering this model I called them and let it be known that the holes were not the correct size for the receiver dryer so that maybe the reason they dropped it. There is a lot of other companies that offer a like condenser for $200-$220, this was the cheapest option I found.
35 Degrees in Florida in stop and go traffic!
Old 09-01-2011, 12:11 PM
vinyl_tien
vinyl_tien's Avatar
Default picture
Hi Tampa 928s
Thanks for your info, can you show me some picture of your? I might love to buy one!
(I live in Taiwan, hot summer is about 37C)
Core 22 inches
Height 14 inches
Thickness 3/4 inch
Old 11-16-2011, 07:09 AM
Hilton
Hilton's Avatar
Did anyone ever follow up these parallel flow condensers for 87-91 manual 928's? (i.e. taller condenser as there's no auto trans cooler sitting above it)
http://www.americancondenser.com/inf...RSCHE-928.html
I need a new condenser for one of my 928's (it did leak), and this occurred to me after seeing what I'm guessing is the same condensers on ebay for $160:
http://www.ebay.com/itm/1987-1988-19...-/120619760192
Old 11-17-2011, 01:08 AM
svpmx83
svpmx83's Avatar
Kooler Car up here in Brisbane has the drawings and details for the kit in mine.
It's a Toyota Hilux core with pretty funky laser cut mounts for a spal pusher fan.
Let me know if you want the details or a better piccy
Old 11-17-2011, 01:31 AM
Glenn Evans
Glenn Evans's Avatar
An independent workshop here in Sydney, which does mostly 928 work, has been fitting parallel flow condensors for some time (a few years now, I think). All reports on the performance of the aircons with them fitted have been good.
Quick Reply: Parallel-flow condenser for late 5-speed?
