Progress on my first 928
Well she's in the garage and all cleaned up. Have not done much so far, but here is a breakdown.
The driver seat is now fixed, the left side flex drive shaft was just un-plugged. Passenger side will still not go forward, will take apart the switch and inspect and clean the contacts.
Tonight I went through the fuses and relays with a fine tooth comb, here is what I found.
Fuses:
#6 Light: Button Panel, Light switch = no fuse, is this used in my 85s.
#11 for the rear window wiper should be a 7.5 but had a 10 in it.
#13 Supplementary AC should be 15 but had a 25 in it, but I don't get this one, is it used?
#19 Rear defroster should be a 25 but had a 30 in it.
#25 Headlamp washing should be 25 but had a 20.
#26 Tailgate release had a 3 in place of a 1.
Relays:
Everything looks good here, except it looks like the power window relay was replaced at some point.
Red wire A is for an old autopage alarm that is mounted under the steering column. Whoever installed did a chooch job, it's coming out.
Grey fuse holder B, is just loose and cut off. I wonder what it was for, will have to trace the wire.
I broke the two plastic tabs on the sunroof motor cover, doh! Will have to fix that later.
I got the proper size battery in now, the old one was loose and would not hold a charge.
Interior all cleaned up, 0 issues here (minus the sunroof thing I messed up). I have moisturized the leather twice now and looks amazing, no need to recover anything.
Tomorrow I'm going to start dismantlement for the TB and WP, once I get in there I'll be talking to Roger to get parts.
Oh and I noticed that the car has plugs from rustproofing, probably Krown. I assume that is not stock. As soon as she is road worthy I will get her sprayed again. Any thoughts?
Oh and after the TB job I will get under and release the built up pressure on the thrust bearing.
Then she is going to go into storage until next year. I though of waiting till next year to do the TB, but I just don't want to risk the short drive to my mom's house, with my luck the freaking belt would snap as I rolled into her driveway!
I know the car was only driven 1000k in 2009 and nothing since, so I'm sure the belt is on it's way out. 4-5k per year prior to 2009. And no service records.
Any way that is my story so far.
Fuses:
Relays:
The relay with the red arrow pointing to it in your photo is the relay for the windows/sunroof. That is what the OEM relay looks like, black plastic, not a replacement.
