928 Forum 1978-1995
Sponsored by: 928 Specialists
ohm reading o2 sensor
Old Aug 26, 2011 | 10:36 AM
smyth1's Avatar
smyth1
Default ohm reading o2 sensor
anyone know of a good ohm reading to troubleshoot my o2 on an 87.thanks.
Old Aug 26, 2011 | 10:40 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
The usual test is to check output voltage - zero to one volt dc.
Old Aug 26, 2011 | 01:53 PM
Eplebnista's Avatar
Eplebnista
Using a digital meter, connect the voltmeter between the O2 sensor wire and ground.
With the engine idling, the sensor voltage should be cycling from low voltage to high voltage. The signal varies between 0 and 1 volt.
If the voltage is continually high, the air/fuel ratio may be rich or the sensor may be contaminated by RTV sealant, antifreeze, or lead from leaded gasoline.
When the O2 sensor voltage is continually low, the air/fuel ratio may be lean, the sensor may be defective, or the wire between the sensor and the computer may have a high-resistance problem
You can test the sensor's reaction by disconnecting a vac line force a lean condition and, if the sensor is working, low output voltage. Conversely, you can unscrew the burner head from a propane torch and feed propane through a big vac line (being careful not to blow yourself and your car up) to force a rich condition and continually high voltage.
