Anyone interested in a mostly complete twinscrew supercharger system?
#61
Administrator - "Tyson"
#62
Looks like the in-tank pump was removed from the part that threads into the fuel tank and the recesses that housed the in-tank pump electrical connections were filled with epoxy? In which case, there is now no strainer between the tank and the main fuel pump...
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#63
Archive Gatekeeper
A stock in-tank fuel pump, with the pump, leads, and connecting hose cut off? I guess the epoxy is there to submerge the exposed wire leads?
Erik- Does Tim have the uber-strainers available now? I still want one but it sort of fell off my radar. Shall I just hassle him directly?
Here's my ghetto version for use when re-inflating gas tanks...
![](https://webfiles.uci.edu/redwards/public/Plugged%20internal%20fuel%20pump%207-12-10.jpg)
#64
If the 044 pump is not needed for your application, spend the $75 and buy the factory piece / strainer
https://rennlist.com/forums/8516374-post22.html
#65
What I found when hunting for my fuel leak at the rear was that the plastic terminal inserts that the wires are connected to were leaking fuel.
When i taped one it fell out.
Since the in-tank pump hose was cracked, and due to what some of the other threads on the in-tank pump said, I decided to remove the pump, snip the wires and terminals off clean and epoxy everything back in. extra epoxy went into the back for extra sealing.
I had a nice fine filter from my carb rebuilding days that got clamped on the end for now.
I am interested in buying the one on the right.
Originally Posted by hacker
You guys really need to look at this photo. The outlet size of the in-tank pump piece (on the far left) is smaller than the factory strainer piece (middle) when a single pump is used.
http://forums.rennlist.com/rennforum...74-post22.html
