928 Forum 1978-1995
Sponsored by: 928 Specialists
Newbies take heed!
Old Aug 22, 2011 | 09:08 AM
por85928's Avatar
por85928
Default Newbies take heed!
I am a newbie myself and am starting an extensive project. My first post was to ask why my car would not start after it was hot, I recieved a lot of excellent information from the very experienced members of this list. What really stood out were things like this "Now its probably time to engage at the next level and punch-list the electrical system. And its the perfect time to change the fuel lines, which is numero uno refresh item on any one of these cars."
"Don't forget the fuel lines, the car can burn so fast you wouldn't believe it."
Also I saw a couple of burnt 928's in different threads. So I took heed to what Landseer was saying and I decided to take the time to check it all before I tried to drive the 928 again...This is what I found under the intake. The first picture is of some kind of a nest under then intake sitting in the vally and the second is a picture of the rear fuel line that was pretty much over the top of the nest. I barely touched the fuel line and it cumbled in my hand. That would have been a big fire! Thanks to the members I was not another poster putting a picture of their 928 burning up. These guys know what they are talking about, if you ask their advise be smart enough to follow it.
File Type: jpg
Old Aug 22, 2011 | 09:35 AM
Lizard928's Avatar
Lizard928
You're lucky, that was a return line and not a high pressure line!
Old Aug 22, 2011 | 09:47 AM
Landseer's Avatar
Landseer
Low pressure, but with substantial volume.
Local shop had an 84. Told the owner we wouldn't work on it unless fuel lines were included in the scope.
They were flexible, looked ok. But we insisted. Backside of one, not visible until removed, had been chewed almost thru the inner liner by evidently a rodent.
Old Aug 22, 2011 | 10:00 AM
por85928's Avatar
por85928
Thanks Chris for your advise! Saved my car
Old Aug 22, 2011 | 10:09 AM
Landseer's Avatar
Landseer
You are welcome, but its really not my advice.
Its me re-iterating the same advice I got from dozens of experts and enthsiasts on rennlist 928 forum.
I just unfortunately have too much time on my hands, am obsessed, and am blabbing out (their) advice faster these days.
Old Aug 22, 2011 | 10:40 AM
jeff spahn's Avatar
jeff spahn
Welcome to the wrenching club. You are gonna like it. Be sure to cover those intakes! Also, before you button it up, stick your shop vac in there and suck up all the stuff that probably fell down in while you have been working. You don't want to chew something up with a piston.
Old Aug 22, 2011 | 10:51 AM
por85928's Avatar
por85928
Originally Posted by jeff spahn
Welcome to the wrenching club. You are gonna like it. Be sure to cover those intakes! Also, before you button it up, stick your shop van in there and suck up all the stuff that probably fell down in while you have been working. You don't want to chew something up with a piston.
Already have done both! What a mess it was.
Old Aug 22, 2011 | 11:20 AM
jeff spahn's Avatar
jeff spahn
BTW, join Rennlist. It is cheap and the benefits are worth the super low price.
Old Aug 22, 2011 | 11:33 AM
por85928's Avatar
por85928
That is on my list to do too!
Old Aug 22, 2011 | 11:45 AM
NC928S4's Avatar
NC928S4
WYAIT - You should also do a Vacuum line update as well. The kit from 928sRUs is inexpensive and relatively simple to perform.
I'm a newbie too and this Forum is unbelievable. Enjoy!
Old Aug 22, 2011 | 11:50 AM
por85928's Avatar
por85928
If it is rubber or a hose it is getting replaced....It still has Porsche belts, I bet they have not ever been changed.
Old Aug 22, 2011 | 12:11 PM
James Bailey's Avatar
James Bailey
Given that he should be pulling that engine for at a minimum a full reseal lots and lots of things are going to need replacing.
Old Aug 22, 2011 | 12:22 PM
por85928's Avatar
por85928
Hey James the engine is coming out. Not quite as easy as an early 911.
Old Aug 22, 2011 | 12:38 PM
theshow72's Avatar
theshow72
May car sat for a few years. I replaced the fuel pump, filter and screen this summer. I jumpered the fuel pump to build up pressure and the rubber fuel lines in the engine just started bursting. I'd fix one and the next one would burst. They just crumbled like sand.
Old Aug 22, 2011 | 12:48 PM
James Bailey
Correct little wonder why the "Porsche techs" tended to really dislike the 928 when it came out.... water cooled, way too much electrical stuff, little access to many things, automatic trans on many, completely different car .......which in many ways was a GOOD THING.
