Blower Fan Motor Replacement
#91
Rog...
is this blower and harnes upgrade still available.?
i have easy access to it all now that I will never have again without a lot of work..
if so..add it to the spoiler order. TA.
as a data point, i just videoed this. Amps as installed in the car.
#92
Here's a tip... when you mount the new motor in the housing and check for clearance/free spinning of the squirrel cage, make sure it's oriented correctly, i.e. with the fan facing down.
Why, might you ask? Because the motor shaft has a slight amount of in/out play, and it just may be enough to make a difference. With the fan facing up, the shaft shifts towards the motor, but facing down, it shifts towards the housing opening, taking up that clearance that you thought you had between the squirrel cage and the edges of the opening in the housing.
I got to hear what the fan rubbing on the housing sounds like when everything is all back together.
yup. This.
i checked it out side the car and it was fine. When that long screw goes in from underneath it may distort the case a bit....and mine started to rub.
simple fix...just revove it all and tap the blower fan a little farther down on the shaft. i went just a bit farther than the appx 1mm Rob shows. Works great.
going to see what amps it draw shortly.
#93
Hi Rog,
I am wondering if you still sell these motors, I am after a blower motor for my 85' 944. If you no longer have them perhaps could you point me into the right direction please? Thanks! imi
#94
Has anyone thought about putting a relay into the circuit to help eliminate this problem with the current draw at the panel and wiring? Let the current wiring drive the relay circuit and run a fed from the main power feed somewhere. It is not the stock setup but it might be a good move to make. If someone has done this it would be nice to see how they did it. and where they mounted the relay and where the tied into the power source.
#96
Electron Wrangler
Alan
#98
Basic Sponsor
We sell the early Passat motor for $85 - need a little Dremel surgery but works fine.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
cgraner (10-20-2022)
