'86.5 with Corvette headlights
Inventor
Just needs a Chevy engine...
Doesn't look too bad...matches the square bumper lights.
http://cgi.ebay.com/ebaymotors/Porsc...-/120766006156
WP0JB0927GS862181
158/490/494 - monterrey, 8-speakers
319/570 - higher fan speed, rear ac
533/650 - alarm, sunroof
474 - sport shocks
![](http://members.rennlist.org/porken/86VetteHeadlights1.JPG)
![](http://members.rennlist.org/porken/86VetteHeadlights2.JPG)
WP0JB0927GS862181
474 - sport shocks
Porken,
Do you remember how much this sold for on eBay, and whether the Ebay ad actually stated that they were corvette lights?
This is the same car on Craigslist near me right now and on another thread, which I can't link to right now.
Thank you in advance!
{Sent Using The Doctor's Screwdriver}
Inventor
Carlos - no idea, sorry.
How much are they asking for it now?
Received 1,309 Likes
I think this is the car we're talking about.
They're asking 2000$.
http://orlando.craigslist.org/cto/5415963492.html
Inventor
I wonder why the headlights are always up? (Too much silicone?
I'm not sure that Chinese water pump is a good investment.
Thanks, Ken. Didn't know if "Corvette Headlights" came from the actual ad or was just your descriptive label.
Yep, that's the one, $2000 now. Engine compartment seems to always look off, and it looks like some of the organ pipes have been swapped out.
Good question on why we don't seem to find pictures with the lights closed. And, yes, the Chinese water pump was noted in the other thread.
I tried to go look at it today, but it didn't work out. Ah, well, the mystery continues on who did the conversion and how.
Check every hose on the headlight system, could be as simple as one that fell off. Especially check the control hoses on the 2 diverting valves that are under the hood surround between the headlight actuator cans. Each headlight can has 2 vacuum ports, the ones that face forward cause the headlights to go up, the onces facing the rear cause them to go down. If you have a hand held vacuum pump I would suggest you test each can. apply vacuum to the rear port of each, once the headlight is down the can should hold vacuum. If it fails to hold the diaphragm is shot and the can will need to be replaced. If it holds, check the front ports. Once the headlight is up the front ports should hold vacuum, if they don't it's a simple fix to replace the "witch's hat" seal on the actuator. Here's a link to more info on the vacuum system:
