928 Forum 1978-1995
Sponsored by: 928 Specialists
digi dash mileage display
Old Aug 20, 2011 | 02:34 AM
h2pmr's Avatar
h2pmr
Default digi dash mileage display
i have a 2 digi dash instrumnent panels both removed from 1990 model's ROW,but cannot remember the exact mileage.
does anybody know which terminals/pins i will need to power and earth just to get a mileage reading?
thanks in advance
Phil
Old Aug 20, 2011 | 05:15 AM
JPR928's Avatar
JPR928
Hi Phil
Where did you get these? And why do you need 2? ;-)
I actually might need a dash with a KMH read out... for a 90.
I'm not sure if the authorities here in the EU will actually accept my current analog MPH read out...
Eventhough I can set the digital reader below to KMH...
Kind regards,
John
Old Aug 20, 2011 | 06:29 AM
h2pmr's Avatar
h2pmr
hi John
i have broken/parted out 2 1990 928's but did not keep a record of the exact mileage.
i am in the UK so display is in MPH,sorry.
Phil
Old Aug 26, 2011 | 07:44 PM
Leon Speed's Avatar
Leon Speed
Technical bulletin 9302
928 S4/GT/GTS/ 89-on
Concern: There are certain instances where the mileage of a particular vehicle must be known, either for various State Department of Motor Vehicles or insurance company investigations.
If a particular vehicle has been involved in an accident which prevents the vehicle’s electrical system from being activated, then the backlighted instrument cluster can be removed from the vehicle and mileage readings can be obtained through the following procedure.
Make a suitable electrical jumper, or if the wiring harness which is in the vehicle is not going to be used, the section going to the #2 connection (A in Figure 1) of the instrument cluster can be cut from the harness and used as a jumper (see Figure 7). Apply 12 volts to terminals 17, 16, 13 and 12. Apply ground to terminals 15 and 14 (see Figure 2). The total vehicle mileage and trip mileage can now be read in the display.
