What is this ?
After looking at the starter #33 post on grounds, i can tell you my car does not have them where that list says they are.
anyway, i removed the cover in front of the front wheel to get access to my drivers side headlight that was not working, and YES, i found the broken wire. One thing i can now check of my fixit list. Also found a ground from the housing of what i think is the power steering pump to the frame. All cleaned.
Under the cover was a 3 inch diameter cloth hose about 2 feet long. It isnt connected to anything, the one end is a niice clean cut on the end, the other looks like it was torn away from something. there is a wire connected in the middle. The only thing i can assume is that it cools that chamber ? Any idea? i cant see what the bottom of it ever connected to.
Now back to the inermiottent spark, i have cleaned 7 grounds so far. Yesterday it started up, today just cranking. You guys have been helping me with this, and we have concluded it is not no fuel or timing belt not turning, or i think grounds, just intermittant spark
if the duct is missing the stones will get sucked into the rear of the alternator
